mksaxton wrote:E85 usually has an octane rating of 100-105, while regular gasoline is 87-93. Also, I might be wrong here, but i believe that E85 has a lower heating value and wouldnt this reduce the power output of the engine?
SnoPro wrote:I want to run it because it is cheep, supports the local economy, and makes more hp (dyno proven). Even though it does have less btu's than gas. It contains more oxygen and that is one of the reason you have to put bigger jets in. I am also unsure if the fuel line can take the E85.
SnoPro wrote:This is no performance secret. The aftermarket is taking full advantage in the automotive market with E85 carbs and supercharger kits. Even with the stock low compression an engine makes a bit more hp not alot but more. I know to take full advantage of E85 you need more compression. I have been looking at a high compression piston but I wouldn't be able to run pump gas when I get out of range of the E85 pump on the trails up north.
