'07 head fit on '08
  • Mikey350D
    '07 head fit on '08
    by Mikey350D » Mon Mar 17, 2008 12:48 pm
    Anyone know if an '07 head (entire assembly) will work on a '08 CRF250??
    Have an '07 head with SS valves, Faction says they're not coming out with SS valves for '08 until May :cry:
    Thanks
    Re: '07 head fit on '08
    by Asmith » Mon Mar 17, 2008 5:05 pm
    Mikey350D wrote:Anyone know if an '07 head (entire assembly) will work on a '08 CRF250??
    Thanks
    It will work just fine.
    BTW - the only valves that are different on the 2008 are the exhaust valves, the intakes are the same on all years. The FactionMX intake stainless valves will fit just fine in the 2008 head.
    The 2008 exhaust valves have a smaller stem - 4.5mm, all previous years have the 5.0mm stem.
  • ThumperX
    by ThumperX » Mon Mar 17, 2008 5:20 pm
    Thanks
    Does a smaller exhaust valve stem benefit anything performance or maintaince wise?
    05' CRF250X
    07' CR250R
    02' CRF450R
    by Asmith » Mon Mar 17, 2008 5:41 pm
    Thanks
    Less mass. Less valvetrain resistance. Plus+++
    Less surface area. More heat retention. Minus---
