Changed fork oil
  • Jason
    Changed fork oil
    by Jason » Tue Jun 28, 2005 1:48 pm
    Since I had the forks off installing a new triple clamp and stabilizer (Thanks Ken) I decided to change the fork oil. I went with 400cc of 10w and set the comp to 11 turns out and rebound 10 out from full hard. I weigh 190 w/o gear and have been throwing new springs around but for now this works good. On the smaller stuff it feels the same as what I had before but it doesn't feel like it bottoms like before. I went 40ft on a 30 footer and to my suprise it didn't hurt like it use to.
    Just thought I'd share for all you other's pushing 200.
    Gravity is the only reason I have scars.
    2005 CRF 250R Twin Air Filter W/Sealing kit-JD Red Needle 5th Notch-175 Main Jet-Boyesen Acc Cover- JD Power Surge
    1971 Zuki 185
    by crfsonly » Tue Jun 28, 2005 10:22 pm
    jason...good information. fork oil height will affect just the last few inches of travel...so, it will help with bottoming.
    glad the triple and stabilizer is working for you.
    Jeff4510
    fork oil
    by Jeff4510 » Thu Jan 04, 2007 6:11 am
    anyone else change the weight/amount of the oil with good results?
    Jeff4510
    where
    by Jeff4510 » Sat Jan 06, 2007 3:17 pm
    Hi, is there any how to artice on this?
    by XGiant » Sat Jan 06, 2007 5:51 pm
    I just got off the treadmill \:D/ . While I work out, I watch TV (I have a sweet setup in the garage). Today I watched the Honda Fork Maintenance video that Ken sells. The guy is a bit dry, but it is ALL the information you will need to do a complete fork job. I am having my suspension done, but since I have the video... :D Here is the link:
    http://www.crfsonly.com/catalog/product ... 1cfef59c8d
    Jeff4510
    just did it
    by Jeff4510 » Sat Jan 06, 2007 6:20 pm
    I just did it a few hours ago, pretty easy actually if you follow the service manual instructions. I used a flathead screwdriver with a mark on it to measure it.
