2005 crf450x turnedinto a r
  • shifte72
    by shifte72 » Sat Feb 16, 2008 9:12 pm
    I have seen on here some thing about cutting a Pink wire ? were is it. on the black box ? and what does it help do? I have made my X into a R with 22mm triple trees a R leak jet, power now, pro circuit ti4 slip on mb1 suspension. and a victor cam. I have a 08 450 black R now. I love it but i would like to get my X to cost more. it seems the engine brake's more on the x then the R .could it be the black box is retarding the timing? vers the r box? the x would be the same as the 08 r if i could just get more free costing into the turns you just have to stay on the gas or it decelerate so much .
  • motomanx
    by motomanx » Sat May 22, 2010 7:17 am
    turn your idle up a bit
  • slomotobug
    by slomotobug » Sat May 22, 2010 11:35 am
    slipper clutch
  • bamm
    YUP
    by bamm » Sat May 22, 2010 11:39 am
    450R :D
  • innovativemotorsports
    by innovativemotorsports » Tue Aug 10, 2010 9:56 am
    My understanding is the R has a longer stroke by like 1 mm, different valvetrain and more agressive cam.
    Oh and of course the x has the wide ratio trans which I like!
    by Asmith » Tue Aug 10, 2010 10:02 am
    innovativemotorsports wrote:My understanding is the R has a longer stroke by like 1 mm, different valvetrain and more agressive cam.
    Same bore and stroke, essentially same valvetrain.
    The cams are MUCH more aggressive.
