valve shim diameter??
  • rigoscrf
    by rigoscrf » Fri Feb 08, 2008 8:15 pm
    Is there a differnce between intake and exhaust shim diameters? The Honda parts finder shows different reference numbers on the fische (16 and 17). I measured with a "cheap" digital caliper and they both seem to be at 7.46mm. I don't plan on using OEM shims but, am just curious if there is an actual difference. Also, I just installed the faction intake kit and the exhaust shims seem to fit fine.
    Thanks
    by [email protected] » Fri Feb 08, 2008 8:59 pm
    They are the same. The 250 thumpers of all brands use the same size shim 7.48 intake/exhaust , same with the 450's except they are 9.48's. Doug
  • rigoscrf
    by rigoscrf » Fri Feb 08, 2008 9:11 pm
    Thanks for the info. Will search tomorrow.
    by [email protected] » Sat Feb 09, 2008 6:21 am
    What did you do to your valve seats and guides anyway ? Doug
  • rigoscrf
    by rigoscrf » Sat Feb 09, 2008 7:39 am
    The stock titanium valves looked fine and clearance was okay. I just upgraded/downgraded to the steel intake valves as preventative maintenance. The seats and guides look good. I purchased the bike as a basket case; due to exhaust rocker arm failure and am slowly bringing it back to life.
  • rigoscrf
    by rigoscrf » Sun Feb 10, 2008 12:59 am
    Thanks for the heads up. I do realize that I am going by visual only and no I am not a CRF specialist. However, I have been a Honda auto tech. for about seventeen years and am willing to give it a try as is. I lapped all valves and they look good. I don't think the bike has had to much use on it but, did notice an engraving on the cylinder head that read SL40. I am not sure what it stands for but am "guessing" that it had some recent work to it. Anyways, tearing it back down is not too big a deal.
