I need help!
  • crf100rider21
    I need help!
    by crf100rider21 » Wed Jan 09, 2008 1:35 pm
    I need to get into my carborator, but one of the screws is stripped!
    Is there any way to get it out?
    Or do i have to buy a new carb?
    Ben
    Honda crf230
    big gun pipe
    Power up kit
    pro taper bars
    protaper bark busters
    Mazda b2300
    tinted windows
    custom sound system
    flo tec with dauls commin out the back
    Malindor
    by Malindor » Wed Jan 09, 2008 2:08 pm
    Stripped in which way?
    The head of the screw, or the threads?
    If it is the head, often you can use a dremel tool with the disc cutter to make another grove...
  • crf100rider21
    by crf100rider21 » Wed Jan 09, 2008 2:29 pm
    The head is stripped, that is what i was thinking about making another grove. I don't have one of those tools is there another way to do it?
    Ben
    Honda crf230
    big gun pipe
    Power up kit
    pro taper bars
    Mazda b2300
    tinted windows
    custom sound system
    gal8x
    by gal8x » Wed Jan 09, 2008 3:45 pm
    Which one is it?… Exactly.
    If the head is stripped then there are a number of ways to remove it.
    More than likely channel locks will do the job. Or a very small stilson.
    Next time use a socket or box end wrench of the right size. Carb bolts are not supposed to be so tight.
    2005 CRF450X (plated)
    zak13
    by zak13 » Wed Jan 09, 2008 4:08 pm
    its a screw
    sellin my xr100
  • crf100rider21
    by crf100rider21 » Wed Jan 09, 2008 7:05 pm
    yes it is a phillips head screw.
    I think i am gonna cut a new groove in it.
    Ben
    Honda crf230
    big gun pipe
    Power up kit
    pro taper bars
    Mazda b2300
    tinted windows
    custom sound system
    heybuddy1901
    by heybuddy1901 » Wed Jan 09, 2008 7:31 pm
    hacksaw.. or maybe even a file..
    whatever you do though!
    try not to knick the carb, the metal is very soft.
    even more so inside, so just take your time and be careful
    SupermotoUSA#858
    www.Brandon858.com
    My dirtbike has slicks!
    gal8x
    by gal8x » Thu Jan 10, 2008 5:41 am
    You need to add an impact screwdriver to your tool collection.
    http://autorepair.about.com/library/ima ... 5a-lib.htm
    luck
    8)
  • crf100rider21
    by crf100rider21 » Thu Jan 10, 2008 12:54 pm
    What does that do?
    Ben
    Honda crf230
    big gun pipe
    Power up kit
    pro taper bars
    Mazda b2300
    tinted windows
    custom sound system
    by krisrtch » Thu Jan 10, 2008 1:14 pm
    Can you get a small a pair of vise grips in there to pull it out? Or is it countersunk?
    Malindor
    by Malindor » Thu Jan 10, 2008 2:07 pm
    The impact of your hammer striking the impact screw driver will break the screw free without stripping it. But it sounds like it is too late in your situation...
  • crf100rider21
    by crf100rider21 » Thu Jan 10, 2008 3:56 pm
    I worked for at an hour trying to get that out. It took my dad 5 mins! He used to be a machinest so he knows his stuff, but i cant believe he did it that fast! I feel dumb!
    Ben
    Honda crf230
    big gun pipe
    Power up kit
    pro taper bars
    Mazda b2300
    tinted windows
    custom sound system
  • crf100rider21
    by crf100rider21 » Thu Jan 10, 2008 5:00 pm
    So now that o got it off. When i turn the bike on gas runs out the over flow tube????
    Ben
    Honda crf230
    big gun pipe
    Power up kit
    pro taper bars
    Mazda b2300
    tinted windows
    custom sound system
    by Asmith » Thu Jan 10, 2008 6:06 pm
    crf100rider21 wrote:So now that o got it off. When i turn the bike on gas runs out the over flow tube????
    Your float valve is stuck open.
  • crf100rider21
    by crf100rider21 » Thu Jan 10, 2008 6:07 pm
    well that is what i thought, but i put everything back in right and the float moves freely
    Ben
    Honda crf230
    big gun pipe
    Power up kit
    pro taper bars
    Mazda b2300
    tinted windows
    custom sound system
