crf 100 fork oil
  • kevindepot
    crf 100 fork oil
    by kevindepot » Fri Jan 04, 2008 11:00 pm
    About to replace the springs and oil in my sons 100. What is the measurement for how much oil? I'm talking inches from the top with the springs removed and the forks compressed.
    by Asmith » Fri Jan 04, 2008 11:09 pm
    The oil level should be 8.15 inches below the top of the fork pipe with the forks fully compressed. The Fork Fluid Capacity: 2.8 +/- 0.08 US oz.
    zak13
    by zak13 » Sat Jan 05, 2008 8:28 am
    ~ wrote:The oil level should be 8.15 inches below the top of the fork pipe with the forks fully compressed. The Fork Fluid Capacity: 2.8 +/- 0.08 US oz.
    what!!!
    8.15?
    i say with some 20 w oil 100mm or 4 inches from the top.
    sellin my xr100
  • kevindepot
    by kevindepot » Sat Jan 05, 2008 8:56 am
    Talk about 2 different measurements! It looks like with the forks compressed they are only about 13" long.
    zak13
    by zak13 » Sat Jan 05, 2008 10:18 am
    i have an xr100 (same bike, diffrent year) and im running 20w at 4 inches below top while fully compressed.
    8 inches is wayyyy to low.
    i think hes talking about big bikes maybe.
    sellin my xr100
    by Asmith » Sat Jan 05, 2008 10:42 am
    zak13 wrote:i have an xr100 (same bike, diffrent year) and im running 20w at 4 inches below top while fully compressed.
    Nope. Are you measuring with the spring in? Are you running more oil to stiffen the front forks?
    zak13
    by zak13 » Sat Jan 05, 2008 11:02 am
    the 20w is stiffening the front suspension.
    the oil level i gotr is from socalxrs.com and its worked for me perfectly.
    its a little stiffer than stock but its plush but resists bottoming.
    i reccomend it for everybody with a xr100 or similar bike
    sellin my xr100
  • kevindepot
    by kevindepot » Sat Jan 05, 2008 11:48 am
    My kid's not what you would call skinny and I'll be blasting around on it at times also. So stiffer is better.
    zak13
    by zak13 » Sat Jan 05, 2008 1:14 pm
    im not what youd call skinny either.
    so that will work good but make sure you put equal amounts in each fork.
    sellin my xr100
