07 CRF250R wont kickstart
  • sven707
    by sven707 » Wed Jan 02, 2008 9:03 pm
    I bought a used 07 CRF250R that wont start. I can start it by pulling it behind a quad and it will start when the engine gets around 4000-5000 RPM. If I try to let the bike idle down, it just dies and wont kickstart. Even if I adjust the idle way up so that it will stay running, it wont kickstart after I shut it off. I don't really know where to start eliminating possible causes. I am pretty sure they don't allow quads and tow straps on the starting line, so any help would be greatly appreciated.
    by Asmith » Wed Jan 02, 2008 9:08 pm
    Check pilot jet.
    Check valves.
  • sven707
    by sven707 » Wed Jan 02, 2008 9:20 pm
    I'll check the pilot, and do you mean valve clearences or should I also look for something else. To look at the bike, it only appears to have been ridden 2-3 times (no wear on engine cases or frame, original tires and grips) so I was kind of hoping it wouldn't be anything major. It will be a good learning experience for me. Thanks.
    by Asmith » Wed Jan 02, 2008 9:22 pm
    Yes. Valve clearances.
    One of the symptoms of a closed intake valve is hard starting. Only able to be bump started.
  • sven707
    by sven707 » Wed Jan 02, 2008 9:25 pm
    I'll post again after I check them, thanks again.
    by Asmith » Wed Jan 02, 2008 9:27 pm
    sven707 wrote:I'll post again after I check them, thanks again.
    http://crfsonly.com/howto/crf250x/crf-v ... stment.php
  • sven707
    by sven707 » Thu Jan 03, 2008 4:09 pm
    I just checked the valves,
    Intake = .005" or .127mm
    Exhaust = .015" or .381mm
    I think intake was actually in spec and exhaust has too much clearance. I am on my way to the store for a new shim kit (I can't find mine!). I went the valve route first because I wanted to check them any way. I will check carb/jets tonight.
  • sven707
    by sven707 » Fri Jan 04, 2008 9:17 pm
    Still no start.
    Valve adjust went as it should, as described. Punch mark on gear lined up, 2 marks on cam gear level, lobes pointing back and all valves are now in spec.
    Carb was/is clean and stock, but I put a new 42 (stock) pilot in just to make sure.
    I can hear the hot start action opening and closing properly (if thats possible) I adjusted the idle till the slide went all the way down to its lowest position (which still has a small elliptical opening) and then I raised it back up about 1-2 millimeters.
    I checked for air leaks at boot
    I checked for spark at the brand new plug (just by eye, I don't know how to test or troubleshoot electrical yet)
    Then I kicked forever and no start.
    Yesterday, the new plug that I took out after I bump started it was wet and looked fouled, like a 2 stroke, black and wet.
    I just don't get it, I have had about 10 CRF250Rs and I feel confident in my start procedure. What should I try next?
    HondaRacer213
    by HondaRacer213 » Fri Jan 04, 2008 9:42 pm
    Magneto? Just my 0.02....
    HondaRacer213
    by HondaRacer213 » Fri Jan 04, 2008 9:44 pm
    Sorry, check the magneto. Even if the plug is firing, it doesnt mean that it gives enough of a charge to start the bike.
  • sven707
    by sven707 » Fri Jan 04, 2008 9:55 pm
    Do you know of a how to on how to check that, and is the magneto the same as a CDI? I am a complete novice at electrical. Thanks
Users browsing this forum: Google [Bot] and 9 guests
