My Problem: the shroud plastic slipped off the bolt, and i cant get it back on. so i need to remove the bolt and put it back through the plastic then put it back on.
Any one understand this post?
usmc88fan wrote:If you have the bolt stuck in the hole still, try to get a small flat tipped screwdriver in there, and hold it tight while you extract the bolt. If you can get the bolt out, use a washer to prevent it from coming back through the plastic. Let me know if that helps any!
