2 smoke jetting?
    2 smoke jetting?
    by krisrtch » Fri Nov 16, 2007 4:24 am
    Hello all,
    Well I own a 2006 CR250 and i rejetted it after putting on a FMF SST pipe. Well the temp has dropped to about 40 to 50 for my final race Sat night. It has been about 70-80 on race nights. and my jetting was pretty spot on. I was wondering now that the temp has dropped what would be best coarse of action. When I jetted it i went down one size on both main and pilot. and air screw 1.5 turns out. Would I be able to get away with turning the air screw in a half turn Or would be putting the stock jet be the best way to go. Any help would be greatly appreciated.
    PS i'm at 20' above sea level
    mustang
    by mustang » Fri Nov 16, 2007 4:29 am
    how is it running in the cooler weather with your current s/u ? any engine likes bigger main jet in colder weather .
    c-ya****mustang Image
    by krisrtch » Fri Nov 16, 2007 5:49 am
    It was running a weird last night just didn't wanna idle worth a darn. Seemed a little off when I got on it. Took a little longer than normal to get up on the pipe.
    by krisrtch » Fri Nov 16, 2007 4:44 pm
    WEll I got home tonight and pulled the plug out and she looked great nice and brown. Guess I go tthe jetting on for cold weather not hot. I 'll try the stock jets when it warms up again and see what the plugs look like.
  • Mikey350D
    by Mikey350D » Mon Nov 26, 2007 6:49 am
    Do you use race gas??
    I mix 50/50 pump/race (CR125)
    I have had huge jetting problems in the winter when the pump gas formula changes.
    Not sure what they do; add ethynol?
    50/50 mix insures fuel is consistant
    by krisrtch » Mon Nov 26, 2007 7:10 am
    Nope all I run is 91 Octane pump gas. I can't afford 9 bucks a gallon for race gas. i check my plug and the plug is a nice golden brown and she has been running like a champ.
