Pooping Noise?
  • 07230
    Pooping Noise?
    by 07230 » Tue Nov 06, 2007 10:02 am
    I have posted this question on Thumper Talk so I thought that I would try it here.
    I have a 2007 230, 120 main, 45 pilot and needle in the 4th position. Everything was running fine with the stock pipe (baffle out), until I added a new Pro Circuit T-4. Now it is a making a popping noise on deceleration. The fuel screw was out 1 1/2 now out to 2 turns and still no change. I know this is a good combo. The plug is pulled out of the top of the air box. I was wondering if the new pipe is causing this or will I have to go to a larger main? It has a new spark plug and it is a little white but not too bad.
    07 CRF230 FOR A PROJECT!
    by JAWS » Tue Nov 06, 2007 10:09 am
    I suggest that you take a look at the Jetting database in the sticky at the top of the 230F forum.
    http://crfsonly.com/forum/viewtopic.php?t=13473
    Looks like a lot of people are jetted much richer on the main than you are. I see 128 and 132 there quite a bit. You might also look into the Honda Power Up option available from your Honda dealer.
    heybuddy1901
    by heybuddy1901 » Tue Nov 06, 2007 10:14 am
    my bike usually makes the pooping noise after i ride it hard for a day, its totally pooped!
    lags for a bit and just wants to rest.
    :D :D :D
    SupermotoUSA#858
    www.Brandon858.com
    My dirtbike has slicks!
    usmc88fan
    by usmc88fan » Tue Nov 06, 2007 10:54 am
    I know I make a pooping noise every now and again, but I can't say I've heard my bike make one yet. Maybe she's constipated :oops:
    We have two companies of Marines running rampant all over the northern half of this island, and three Army regiments pinned down in the southwestern corner, doing nothing. What the hell is going on?
    heybuddy1901
    by heybuddy1901 » Tue Nov 06, 2007 11:06 am
    LOL
    anyhow
    i fixed my pooping noise by re-jetting
    now shes all opened up and flows freely
    SupermotoUSA#858
    www.Brandon858.com
  • 07230
    by 07230 » Tue Nov 06, 2007 2:08 pm
    So much for a serious answer!
    usmc88fan
    by usmc88fan » Tue Nov 06, 2007 2:13 pm
    Seriously dude, they are decel pops.
  • 07230
    by 07230 » Tue Nov 06, 2007 2:36 pm
    I know, just trying to find a fix. Time for bigger main jet. This will give me something to do this weekend.
    usmc88fan
    by usmc88fan » Tue Nov 06, 2007 2:42 pm
    I used to get them on my street bike, but the power commander fixed all that. I don't have much experience on the dirt side of the house yet, but if you were to ask Smash or ~, they might have a MUCH better answer.
    jtcohenour
    by jtcohenour » Tue Nov 06, 2007 4:22 pm
    I had the exact same problem with my bike. I fooled and fooled with the jetting with no avail. It turned out that it was an exhaust leak at the header where it connects to the top end. Start your bike in the garage with no fans running and run a match around the header where it meets the top end. If the match is blown out you most likely have a leak. The bolts must be tightened to 14 or 15 foot lbs. I was not able to fix the leak by tightening alone as I had overtightened crushing the brass gasket when I initially installed my new pipe. I had to buy a new gasket.
    usmc88fan
    by usmc88fan » Tue Nov 06, 2007 4:23 pm
    That's an awesome way to test! Thanks JT, I'll keep that in the toolbox!
  • 07230
    by 07230 » Tue Nov 06, 2007 6:58 pm
    jtcohenour, thanks for the advice I will try that tomorrow before I start tearing the carb apart.
    by Asmith » Tue Nov 06, 2007 7:05 pm
    07230 wrote:jtcohenour, thanks for the advice I will try that tomorrow before I start tearing the carb apart.
    Decel pop is caused by either an exhaust header leak ( as referenced by jtcohenour and his clever leak detector) OR by a lean pilot circuit.
    We found that the 48 pilot helped the 230 immensely.
    The decel pop went away, the bike started much easier and warmed up much quicker. Also, since the carb has no accelerator pump, the 48 helps in the low end power as well.
  • 07230
    by 07230 » Tue Nov 06, 2007 7:47 pm
    Looks like I am off to the Honda Shop then to a smoke shop. Unless they sell matches at the Honda dealer. Thanks for alls imput.
    usmc88fan
    by usmc88fan » Tue Nov 06, 2007 8:31 pm
    Let us know how it turns out!! :D
