realslow wrote:I recently tried to shim my valves for the first time. One of the intake valves already had a 120 shim in it and there was zero valve clearance. My shim kit only goes down to 120. What do I do now? do i need to replace the valves/head? Is there a fix for this that is more permanent than stock?
~ wrote:realslow wrote:I recently tried to shim my valves for the first time. One of the intake valves already had a 120 shim in it and there was zero valve clearance. My shim kit only goes down to 120. What do I do now? do i need to replace the valves/head? Is there a fix for this that is more permanent than stock?
Yep,
you are out of shimming room.
Time for new valves.
CRF'sONLY has the FactionMX intake kit which changes them to Stainless steel intakes.
http://www.crfsonly.com/catalog/product ... ts_id/2537
It's $ 166.20 plus 4 OEM Valve seals plus a head gasket.
You will need to have your valve seats recut as well.
BTW - Welcome to the site!!!
realslow wrote:~ wrote:realslow wrote:I recently tried to shim my valves for the first time. One of the intake valves already had a 120 shim in it and there was zero valve clearance. My shim kit only goes down to 120. What do I do now? do i need to replace the valves/head? Is there a fix for this that is more permanent than stock?
Yep,
Thank you. is this solution better than Kibblewhite valves and springs that I have read about on this site?
Users browsing this forum: Bing [Bot] and 1 guest
