2006 crf150 ignition removal
  • crfer666
    by crfer666 » Sun Oct 21, 2007 2:18 pm
    how do i remove the keyed ignition on a 2006 crf150 with electric start. I lost my F$%#ing key. ive taken the gas tank off and there are only 3 wire going from the key to the harness what do i do........
    by Asmith » Sun Oct 21, 2007 2:22 pm
  • crfer666
    by crfer666 » Sun Oct 21, 2007 9:53 pm
    my bike only has 3 wire going from the key to the harness black,black and white, and red
    woodsman
    by woodsman » Sun Oct 21, 2007 10:29 pm
    Disconnect all three. That starts my honda 2003 xr100 and it only has two wires. do the wires connect (to the tubular thing that holds the key) near the key or at the back(farthest from the key)?
    The key turned to the "on" position does not "finish" a circuit as one might think, but rather disconnects a "kill circuit".
    Currently, 05 450X
  • crfer666
    by crfer666 » Mon Oct 22, 2007 4:47 pm
    i did but than my electric start doesn't work and it doesn't have a kick start
  • crfer666
    someone please help
    by crfer666 » Tue Oct 23, 2007 6:19 pm
    i really need help on this topic i want to ride my bike and the only starting method is electric start and removing all wires from the ignition doesn't help
    Re: someone please help
    by Asmith » Tue Oct 23, 2007 6:40 pm
    crfer666 wrote:i really need help on this topic i want to ride my bike and the only starting method is electric start and removing all wires from the ignition doesn't help
    Do you have a meter? Do a continuity test on the three wires coming from the switch. See which two are connected when switch is on. Verify that they aren't when switch is off.
    Then connect those two wires from the disconnected loom.
  • crfer666
    by crfer666 » Tue Oct 23, 2007 6:47 pm
    i don't have the key or metor to
    tell which wire control the electric start
Users browsing this forum: No registered users and 12 guests
