correct oil
  • jt7602
    correct oil
    by jt7602 » Fri Oct 05, 2007 9:11 am
    Hello CRF's - In the supplied manual, Honda recommends GN4 oil for both the engine and tranny. In the little insert they provide, Honda lists HP4M (w/molybdenum) for the engine, and regular HP4 for the tranny. I noticed this after changing the engine oil and filter w/ GN4. Does it matter? thanks, and LOVE the bike!
    Aspired
    by Aspired » Fri Oct 05, 2007 1:38 pm
    I run the HP4 but I don't think it really matters to much but I like the semi synthetics despite the added cost.
    Just make sure you follow which on takes moly and which doesn't if you use it. That is important, you'll see guys run all kinds of oil in the CRF if you look around a bit but just change it at regular or just before intervals and check you valves and you should be fine.
    Enjoy riding!
    The best suggestion - Make sure you have a manual!
    mikey526
    by mikey526 » Fri Oct 05, 2007 6:00 pm
    I run GN4 in the engine side and 80w85 in the tranny.
    Aspired, if your still looking, have you ever ridden at Aztalan Cycle Club?
    Aspired
    by Aspired » Sun Oct 07, 2007 3:35 pm
    mikey526 wrote:I run GN4 in the engine side and 80w85 in the tranny.
    I used to use the 80w85 in my 2 stroker tranny - works well.
    No I still have to get over there found a nice track listing on Thumper Talk but I live in Menomonie which is by Eau Claire (left hand side of WI) this mean I usaully go to MN motocross tracks for MX but limited to much trailriding close by that allows bikes and not just quads.
  • HRC_NICK_11
    by HRC_NICK_11 » Mon Oct 15, 2007 6:05 pm
    OK what is the trick to filling the tranny side? I spilled about a 1/4 of the oil I tried to pour in.
