No spark 50
    bosshaug1
    No spark 50
    by bosshaug1 » Fri Sep 28, 2007 11:12 am
    Kids couldn't start the 50 yesterday -wouldn't fire at all. Checked ignition key, kill switch -all good. Pulled plug, looked ok, but no spark? We are new to maintenance past oil changes/air filter/chain/suspension/etc. Any ideas on what to check next?
    2006 CRF250X -JD kit, R can/PMB endcap, CCC mods, 05Rcam, flatland rad guards/skidplate, street legal
    2005 CRF50F -stock
    by krisrtch » Fri Sep 28, 2007 12:26 pm
    The last time you cleaned the air filter did you take the complete housing off? If so Check the ground wire for the coil that connects to top housing bolt. you may have forgot it. Just my 2 cents.
    bosshaug1
    by bosshaug1 » Fri Sep 28, 2007 1:47 pm
    We have never completely taken the housing off, plus, it has run since last filter cleaning...
    2005 CRF50F -stock
  • michanic220
    by michanic220 » Fri Dec 21, 2007 7:45 pm
    if you checked all your killswitches/keyswitches i'd completely disconnect them to where its not grounding out anywhere, and if you dont have spark look into your stator and trigger coil (not fumiluar if dirtbikes have triggers on em') and check the resistance.. if there good i'd look at your spark plug coil.. on engines you wont change alot of coil's, unless the motor has another problem.. they hardly go bad, all they are is a winding of wire. also look closely at the wires going to and from the coils. you'll probly get spark if you disconnect you're ignition switch.
    hope this helps, if im wrong about anything someone correct me, thanks. -joel
    zak13
    by zak13 » Sat Dec 22, 2007 12:51 pm
    try a new spark plug
    sellin my xr100
  • michanic220
    by michanic220 » Sat Dec 22, 2007 1:36 pm
    left that one out :roll: it might just be that simple.
    bosshaug1
    by bosshaug1 » Fri Feb 08, 2008 9:10 pm
    ...turns out it was the spark plug :o I guess my lesson was getting to know the entire electrical system intimately.
    2005 CRF50F -stock
  • michanic220
    by michanic220 » Sat Feb 09, 2008 11:01 pm
    i just got done meeting mine. after rebuilding my whole engine putting rings in it and a new head and valves. it stopped sparking :x and i replaced all the coils on the stator plate, replaced the CDI and tested the main firing coil and that was good. only thing left was the wiring. well i found a broke wire under the insolation an it was as simple as that.
