throttle tube questions?
  • Dirtbike_Crazy6656
    by Dirtbike_Crazy6656 » Sun Sep 09, 2007 3:19 pm
    Well it finally happened. I was on an extremely rocky trail and I laid the bike over. Normally it would not of been a big deal. It was a very slow tip over. but it managed to brake the throttle tube right in half. what is the best throttle tube to get. should I go with a metal or just go with a plastic?
  • Scotchie
    by Scotchie » Sun Sep 09, 2007 7:19 pm
    Either way you go....your throttle will be functional. A few things to think about though. If you use bark busters like the Pro Bends, and you get a metal one, make sure you get an open ended tube so that you don't have to hack saw the end off. I used a pipe cutter to cut the end off my metal throttle tube off and it pinched the end a bit (just enough to make it rub). Still works but with no snap back. I am replacing it (since I pretty much ruined it) with an open ended metal or open ended plastic throttle tube. If you don't use bark busters I would recommend closed ended billet or something similar because the closed ended design houses rollers/bearings that allow for much smoother operation and throttle snap back.[/b]
    2005 CRF450r Pro Taper Bars and Rubber mount clamps, Big Gun Pipe, Hinson, Ready Racing.
    2005 CRF250r, Race Tech, Hinson, White Bros Aluminum Pro, Scotts Stabilizer, Pro Taper.
    Monkeywrench
    by Monkeywrench » Sun Sep 09, 2007 8:17 pm
    I put an aluminum one on the 250X this past spring, only because the stock plastic one had worn out and become too wobbly. I guess an aluminum one could wear the same way over time -- be sure to grease the contact area between handlebar and throtte tube if you go aluminum. The ones with the bearings in the ends seem like a great idea as well.
    2006 450R
    by Dirtbike_Crazy6656 » Mon Sep 10, 2007 6:47 am
    Thanks for the advice. I thinking that I'll go with the metal.
