Drive Chain Master Link Question
  • yoboom
    by yoboom » Wed Aug 15, 2007 9:13 pm
    Do any of you folks run the continuous style chain that comes stock of the “R” or can I run a standard chain with a “clip” style master link? The shop manual states do not install the clip style master link, only run the crimped on continuous style chain.
    thanks,
    al
    Al
    by crfsonly » Wed Aug 15, 2007 10:40 pm
    you can run the clip style. the did vm chain has both options the rivet and clip style.
    by Aussiecrf230 » Thu Aug 16, 2007 5:59 pm
    Don't worry I have seen the peened over links heads crack off as well as clips come off.
    If it is done properly either stays on just as well.
    I have used clips for twenty years and never had a trouble. Your also more inclined to remove and clean chain and sprockets properly if it comes off without having to move the axle.
