CRF70 Jet Installation
  • sirtrexter
    by sirtrexter » Fri Jul 20, 2007 10:14 am
    Can anyone help me with installing jets on my 05 CRF70? I would appreciate any help that I can get.
    2005 CRF250X fastest at home
    2001 XR100R
    2006 KLX300R
    2005 CRF70F
    1982 YZ490
    1980 DS80 super fun
    1999 Kingquad 300
    Aspired
    by Aspired » Fri Jul 27, 2007 3:13 pm
    Well first you have to get at the carb, seat off maybe more on that model. loosen the band clamps on the front and rear of the carb (one to the airbox, one to the motor) rotate the carb as needed.
    To access the main jet you need to take the bowl off the carb (4 bolts - don't strip them!, then can be tight for factory), the main jet should be in the center of the bowl float area.
    the pilot jet is on the side for lack of better location description
    Be sure just to snug the jets or you can strip them and your screwed, you have a manual, if not you should get one. This will help you explain what jets and needle to use based on spark plug burn.
    Remember you can ruin your motor fast and it gets real $$$$ to fix if you run the wrong jets, if your not sure don't change them and get someone who know what they are doing to help (physically).
    Is the bike running rich and you trying to find more power through tuning or what? Most of the power to a bike is through tuning but be careful!
    Good Luck - looks like you have plenty of bikes, someone should know all this by now or you have like 5 machines that could run a hell of a lot better.
    The best suggestion - Make sure you have a manual!
