Engine Temps
  • malder
    Engine Temps
    by malder » Sat Jul 07, 2007 8:59 am
    I just installed the flatland radiator guards, fuel screw and emission block kit. I went riding yesterday and my bike seemed to be running a bit hot. The ambient temp was very hot - over 100. When moving the temps were in the low 200's and the highest it got was 220 when going on slow 2nd gear twisty trails.
    Is that normal or is something wrong. I'm not certain that I had the fuel screw tuned right. I have the bike rejetted (JD), but have not changed the main pilot yet. The fuel screw was 2.5 turns out. We were probably at 2000-3000' above sea.
    by crfsonly » Sat Jul 07, 2007 12:01 pm
    when installing any radiator guard that protects the front of the radiator make sure you put back on the white plastic air scoops. you will need to cut off the plastic tabs and zip tie it to the radiator. the scoops help collect and direct more air through the radiators.
    djh65
    by djh65 » Sun Jul 08, 2007 10:03 am
    Well after reading that post I zip tied them back on. It was 104 where I was riding and my bike never got over 204. It was getting up to 225 before, what a huge difference.
    Thanks for the tip Ken.
    David
    06 HD450X made in america.
  • cbwbte
    White Air Scoop Location on Flatland Guard
    by cbwbte » Wed Jul 11, 2007 7:31 am
    Do you install the white plastic air scoops in front of the Flatland radiator guard, or between the guard and the radiator?
    Thank you,
    cbwbte
    by [email protected] » Wed Jul 11, 2007 8:24 am
    Does that mean that you still have the stock main jet in ? The stock pilot is usually fine, but the stock main is way too small, and you should have a 162,165 or 170 in there along with your red JD needle. Doug
    djh65
    by djh65 » Wed Jul 11, 2007 8:51 am
    I have the Duval guards and I put the plastic on the outside of the guards. 4 ties each and they look like they belong and really made a difference.
    David
