mods for a crf 80
  • crf80fguy15
    mods for a crf 80
    by crf80fguy15 » Wed Jun 27, 2007 6:21 pm
    i have a 2004 crf 80f and was wondering what mods i could do to it i already have a fmf powercore 4 pipe and a oversized cam in it and what are the best number of teeth on a sprocket a lot of top end torque
    Aspired
    Re: mods for a crf 80
    by Aspired » Fri Jun 29, 2007 8:34 am
    crf80fguy15 wrote:I have a 2004 CRF 80f and was wondering what mods I could do to it I already have a FMF Powercore 4 pipe and a over sized cam in it. What are the best number of teeth on a sprocket for a lot of top end torque?
    You want top end torque then a sprocket will do nothing for you.
    Changing the sprockets (usually only rear is needed) just changes your setup for different riding conditions. More teeth mean more lower grunt and more shifting. Less teeth mean a high top speed, you can run out each gear a little further and less shifting.
    Yeah you'll see slightly more torque with a smaller rear sprocket but you will loose top speed.
    I go down a tooth or 2 on tracks with large hills and lots of muddy tight sections - Up a tooth on ones with large fast straights or long sand stretches. Also depends how you ride, are you a gear high person who clutches, some bikes also have a really low 1st or long 3rd gear, sprockets can make the bike suit your riding style better.
    If your going for torque which is the amount of force require to get an abject to rotate then your current pipe and cam should have helped in those areas.
    IMO if you want more real torque you will need a engine mod, maybe an over bore or stroke but on a 80 I wouldn't bother much, just ride it and when you out grow it get a bigger bike, maybe a CRF150f unless your tall enough to step up to a CRF250f with a lowering link maybe.
    Hope this helps you out some.
    The best suggestion - Make sure you have a manual!
  • philadelphia
    by philadelphia » Fri Jun 29, 2007 10:48 am
    crf80fguy15 wrote:i have a 2004 crf 80f and was wondering what mods i could do to it i already have a fmf powercore 4 pipe and a oversized cam in it and what are the best number of teeth on a sprocket a lot of top end torque
    the best thing u can do is get a new bike like a crf150r alot more speed and still amost the same size
    djh65
    by djh65 » Fri Jun 29, 2007 2:09 pm
    I would say the cr85 would be much faster. The problem is they are too tall. My son is on a kx60 and my only choice for a honda is the crf80.:)
    David
    06 HD450X made in america.
    zak13
    by zak13 » Wed Jul 11, 2007 8:35 pm
    what u can do i think it should be the same but i have an xr100r and what i did wasturn the fuel screw 1.5 turns in and if u take the air filter out take the foam off and u will see a screen look for a tab and pull it up and off the screen then pull the screen off and theres sum stell mesh but i dont know if i should take that off so i left it if u want to take it off be my guest and tell me how it went bec im a noob in that subject then put the foam back on and it will have a lot more tourque and perform way better
