Put new chain on a bike
    Cliff
    by Cliff » Thu May 24, 2007 8:41 pm
    Ok, Mr. Newbie here again.
    I never put one of these non-master link chains before.
    I got the old chain off with no problem, using a chain breaker. And I also took the extra 4 links off the 120-link new chain.
    But how the heck do I put on the new link? Do I need some kind of press tool?
    Thanks
    by JAWS » Thu May 24, 2007 11:27 pm
    If you don't have the Motion Pro set that does both break and press, then you can use something like this:
    http://www.crfsonly.com/catalog/product ... 4c3bbf5d25
    There are others available, just look around.
  • Halen
    by Halen » Fri May 25, 2007 6:57 am
    Ol' Joe is right... I have a chain breaker that both presses the old pin out as well as presses the new one in. Quite simple to do if you have the right tools.
    have fun
    later... Van
    09 CRF 250R
    RMR lowered suspension
    Heavily armoured for the bush
    50 tooth rear
    soft gel seat
    by JAWS » Fri May 25, 2007 7:51 am
    Halen wrote:Ol' Joe is right... I have a chain <snip> Van
    Watch it sonny! :shock:
    Joe :D
    djh65
    by djh65 » Fri May 25, 2007 9:41 am
    Why wouldn't the chain have a master link?
    06 HD450X made in america.
    Cliff
    by Cliff » Fri May 25, 2007 9:56 am
    Thanks Guys, I guess I need to buy that press tool. I wish the Motion Pro guys told me about the combo tool earlier.
    Regarding the last question, my chain is a T-Ring chain, which is stock for the 2006 CRF 250X. It does not have a typical master link where it is secured to the chain with a circlip-like piece. It is press-fit like the other links.
    NCLR1
    by NCLR1 » Fri May 25, 2007 12:04 pm
    I have an 06 250x as well. I am pretty sure that you still have an O-ring chain. It just uses a "T" type o-ring.
    Tony C
    Cliff
    by Cliff » Fri May 25, 2007 6:26 pm
    Hey Jaws,
    You sent this link to me earlier.
    Is this all I need to complete the chain installation? Will it be enough to compress/stake the roller ends on the chain link? Or do I need another tool? I think 'stake' is the correct term to use to describe compressing the roller/pin ends.
    Thanks
    by JAWS » Fri May 25, 2007 6:59 pm
    Yeah, that's all you should need, but you have to know that there are better tools out there,. This is a mini and meant for light duty. If you can afford it, I suggest that you go for the $56.50 Part # 08-0066 CHAIN PRESS TOOL KIT. The mini is good to take on the trail for light duty. If you decide on the mini, it will server for the occasional use.
