Power up (jetting) question???
    CRF230dad
    by CRF230dad » Mon May 21, 2007 12:56 pm
    I have read the sticky and many posts about rejeting. I want to pep up my son's 05' 150 and plan on uncorking the air box but use the stock filter for now (more surface area than the round filters). I will modify the baffle until I can afford a new pipe for him. What I need to know is needle position and jet sizes, fuel screw & idles screw adjustments. We mostly ride So. Calif. upper deserts & Gorman around 2,800 - 4,500 ft. We sometimes ride at Big Bear around 6,800 ft. and are planning to go to Salton Sea or Ocotillo Wells at -45 ft. and 722 ft. but those are not frequent trips. I know one jet size does not fit all but for are routine trips what do you guys recommend?
    Thanks!
    Stock 2005
    CRF230 (Mine) Pro Taper SE CR High bend Bars
    2000 CR250R (Son#1)
    Renthal Fatty Bars
    FMF pipe
    CRF150 (Son #2) Pro Taper SE CR High bend Bars, Pro Circut T4 pipe, Rejet carb, K&N air filter, Open airbox
    2006 Yamaha 350 Raptor (Wife)
