INFO: Handlebars/Cockpit
    In2deep
    by In2deep » Tue May 15, 2007 4:27 pm
    I will be buying new bars, grips, levers, throttle tube and possibly clamps in the near future.
    There used to be a cockpit thread. Understanding that it may be gone I was hoping we could recreate it.
    I would like to see how everyone is set up. Please post a pic.
  • xman
    by xman » Tue May 15, 2007 4:49 pm
    Here is what I'm runin'. I am 6 ft.
    Pro-Taper CR high, ASV levers and perches, Applied triples (22 mm), Applied sub-mount, Scott's dampner, Trial Tech comp, Spider M1 grips.
    Here is another pic, not to great of the controls, but you get the idea. The grips in this pic are Renthal dual compound. I like the Spider M1's WAY better. 8)
    Could you repeat that? In English this time!
    by JAWS » Tue May 15, 2007 6:00 pm
    Here's mine:
    Roady
    by Roady » Tue May 15, 2007 8:37 pm
    Applied Triples (22mm), Scotts, Ipod remote, GPS, document holder, Pro Tapers (Windham bend)
    It is a good day to ride
    by XGiant » Wed May 16, 2007 6:34 am
    Here is my setup (6'4")... pretty standard by CRF's Only standards.
    SoylentGreen
    by SoylentGreen » Wed May 16, 2007 7:36 am
    Here is mine before the Acewell. Pro-Tapers CR-Hi w/Applied mounts.
  • HazzMatt
    Handlebars
    by HazzMatt » Thu May 17, 2007 9:59 am
    Since you guys are on the subject, what is the benefit of this triple clamp setup? I have rode a friends bike with this setup, but was paranoid of wrecking his bike so I wouldn't call it really riding and only noticed the highth difference. It was comfortable while standing but I tend to be lazy and sit on that thing they call the seat. Clue me in on this big mystery of mine cause I was comtemplating a switch.
    Matt
  • xman
    Re: Handlebars
    by xman » Fri May 18, 2007 10:19 am
    HazzMatt wrote:Since you guys are on the subject, what is the benefit of this triple clamp setup? I have rode a friends bike with this setup, but was paranoid of wrecking his bike so I wouldn't call it really riding and only noticed the highth difference. It was comfortable while standing but I tend to be lazy and sit on that thing they call the seat. Clue me in on this big mystery of mine cause I was comtemplating a switch.
    Matt
    The Applied offset triples give much better response as opposed to the stock offset due to the change in rake. Much better for any trail conditions (sharper, more controled turning) They also give a much better feedback to the rider due to the fact that they do not allow as much flex as the stock units. They are stronger than the stock triples. When I first installed my Applieds, I could not beleive how much better the bike felt and how much easier it was to navigate the tight stuff. 8)
    And last.......the bling factor is off the charts. :D
    crazybrother
    by crazybrother » Fri May 18, 2007 6:36 pm
    Here's mine 5'9" Scott's, BRP SUB mount with SX top clamp. Pro Taper bars Carmicheal bend. Stock Triple.
    [img][img]http://img410.imageshack.us/img410/5825/scotts1dl2.jpg[/img][/img]
    [img][img]http://img410.imageshack.us/img410/8307/scotts3ik7.jpg[/img]
    [/img]Image
    2009 Honda 450x (Plated)
    2010 Honda VFR 1200
    2008 Honda CBR 600RR (Wifes)
    chpcrf
    by chpcrf » Fri May 18, 2007 7:12 pm
    here's one but not a good pic
    07 crf450x you have to love these bikes that is all that needs to be said!!!
  • bvillercr
    by bvillercr » Sun May 20, 2007 8:40 pm
    chpcrf wrote:here's one but not a good pic
    Nice rail in the background, where do you race it? Is that a jr. rail?
    too many mods to list, see garage
    chpcrf
    by chpcrf » Tue May 22, 2007 12:36 am
    it's a top comp dragster i'm building it for a customer i like racing door slammers i'll post a few pic's when it's done if your interested
  • bvillercr
    by bvillercr » Tue May 22, 2007 7:24 am
    Please post, I race at bonneville and El mirage with a door slammer. I'll did up one of my pictures as well.
    elmo450x
    by elmo450x » Tue May 22, 2007 11:04 pm
    Help! I'm A first time post'r with a bar question. I tweaked the stock bar up at Rowher last weekend. The hit was relatively mild, I layed it down on the left side climbing a hill, my knee took the brunt of the impact, along with the bar. The left hand side of the bar bent forward. When I replaced it with a new Pro Taper (along with the 11/8th mounts), the bar still seems to sit "crooked" to the right. I've doubled checked my installation, and made sure I torque'd the nuts/bolts to spec. But its still angled to the right. Am I missing something? Should I replace the rubber mounts also? I'll post a pic if needed, but everything seems straight visually, so I don't think it'd help.
    Thanks in advance- Pete
    crazybrother
    by crazybrother » Wed May 23, 2007 6:31 pm
    elmo450x wrote:Help! I'm A first time post'r with a bar question. I tweaked the stock bar up at Rowher last weekend. The hit was relatively mild, I layed it down on the left side climbing a hill, my knee took the brunt of the impact, along with the bar. The left hand side of the bar bent forward. When I replaced it with a new Pro Taper (along with the 11/8th mounts), the bar still seems to sit "crooked" to the right. I've doubled checked my installation, and made sure I torque'd the nuts/bolts to spec. But its still angled to the right. Am I missing something? Should I replace the rubber mounts also? I'll post a pic if needed, but everything seems straight visually, so I don't think it'd help.
    All you probally need to do is loosen the rubber mounts & straighten them out. If that doesen't work then loosen your triple clamps & twist your forks back.
    2010 Honda VFR 1200
