How to check Transmission Oil
  • hondaTim
    by hondaTim » Thu May 10, 2007 2:25 pm
    As far as I know you have to change the oil to 'be sure' what the tranny level is. Is that right?
    Is there any 'trick' or plastic thing I can buy to check oil level?
    Anyone know if there is a third party tranny case cover with a window in it to check tranny level?
    I have a 05 450x. Not knowing the oil level drives me nuts and I dont change the oil after every ride.
    thanks!!
    '05 CRF450x
    mdmasher
    by mdmasher » Thu May 10, 2007 5:48 pm
    Check your owners manual. The transmission has a check bolt hole. Clutch cover area, you should have a bolt with a phillips slot in the head just below the aluminum plug cap that close to your water pump.
    But with that said, please use a full quart of oil on the transmission and not the .69 qt. or 650cc that the book calls for.
    Your trans will not loose or burn oil like the motor side can.??? By that time you would have changed the fluids again. Motor will use .74 qt w/filter change, and the trans uses a full qt.
    05 CRF450X WC,plate&brace.Devol rad. Hand guards.jet.165M #50L.air mods w/twin air filter.Pink.Clarke3.4. CHM pipe.
    80 XR500R old school
    05 Raptor 350 Wifes, Nerf.skids.+
    04 TRX250EX Daughters,Nerf.+
    85 FL350R Odyssey Kick in the A.
  • hondaTim
    by hondaTim » Thu May 10, 2007 5:57 pm
    ahhhh.
    thanks man! I will conslut the manual.
    '05 CRF450x
    NCLR1
    by NCLR1 » Fri May 11, 2007 2:46 pm
    The trans. hole check method doesn't always work. If you find yourself scratching your head wondering why none has come out, don't worry. Just put in a full Qt every time and all will be good.
    Tony C
  • _06_crf_250r
    by _06_crf_250r » Wed May 16, 2007 12:17 pm
    Dads got an 05 450x that I take care of and there is a 10mm bolt between the bottom timing plug and the clutch cover this is the check bolt the way i did it (prior to factory fill) was to put most of the oil in then take out the plug (with the bike upright if you dont have a center stand lean it up) and fill it untill it comes out.
    06 crf 250r
    WB Carbon Pro
    AC subframe
    Pro Taper Contour
    Cycra powerflow fender
    Twin air filter
    works conn radiator braces
    works conn skid plate
    hammer head case saver
    renthal red 49tooth rear sprocket
    renthaul gold chain
    by [email protected] » Thu May 17, 2007 6:49 am
    and fill it until it comes out.
    Better watch that one, that's exactly how a lot of people have thought they were full, they weren't, and they've burnt up their transmission.
    That is why we say to just thoroughly drain your transmission fluid in a 450X, then just pour in a full quart. There have been no ill effects, no extra oil "blowing out", no problems whatsoever I've ever heard of. Doug[/quote]
    dirty mike
    by dirty mike » Thu May 17, 2007 10:23 am
    I recieved a notice from Honda on how to check trans oil. it says run the motor for 3 minutes, wait three minutes then pull the bolt and fill till oil comes out.
    The reason you run the motor is to distribute the oil to all the nooks and crannys. If you check it cold it may be full but in reality it is a low oil condition.
    To be safe and easy just put in a full quart.
    06 crf450x
    e2 pipe
    flatland rad guards
    flatland skid plate
    07 150r expert
  • revs
    by revs » Fri May 18, 2007 12:03 am
    Do you recommend a full quart in a 250x also? if so ,what is that in ml as it says in the manual 750ml ?
    2004 crf250X
    by Asmith » Fri May 18, 2007 5:14 am
    revs wrote:Do you recommend a full quart in a 250x also? if so ,what is that in ml as it says in the manual 750ml ?
    We run about 820 cc (ml) in the 250X.
  • revs
    by revs » Fri May 18, 2007 5:29 am
    Thanks -i was running 800ml -so i wasnt too far off - alot easier than waiting on the check hole to find out if there is enough in .
    2004 crf250X
    by Asmith » Fri May 18, 2007 5:35 am
    revs wrote:Thanks -i was running 800ml -so i wasnt too far off - alot easier than waiting on the check hole to find out if there is enough in .
    I figured that since the Transmissions were of similar design, running a bit more like the 450X wouldn't hurt anything.
    A full quart is 946ml.
    820 ml fits nicely and gives enough room for expansion without blowing any out so that's the number we've gone with.
