by Synergystic-Seal » Tue Jul 10, 2007 1:37 pm
15/16 or 24mm will remove the rebound nut...do this first to drain your oil.
Large channel locks work if you do not have the $$ to spend on a 50mm tool for the compression chamber assy.
Clamp the fork in a vise
heat up the outer tube...not too hot
The assembly will unscrew very easily.
Remove the internal assembly
turn the forks upside down and the spring will fall out.
Let the forks drip dry a bit then shove a clean non-lint cloth into the lower fork tube to clean it a little.
Add your new spring
re-install the internal component assembly
hand tighten it
add 12oz of oil to each fork leg from the rebound side
re-install the rebound nut
Then go ride!!
IMPORTANT...When you re-install the compression unit DO NOT TIGHTEN...JUST SNUG IT DOWN BY HAND
Rob
www.synergyseals.com
Made in America....Economic Terrorist Free!
SPONSORED RIDERS:
Shane Watts
Ty Davis and team (Testors)
Kacy Martinez
Jacklyn Ross
Brian Sperle
Garrison Gragg
Alex Gragg
Eddy Gragg
Justin Williamson
Kyle Krause
