Use grease as glue
  • loff
    Use grease as glue
    by loff » Mon May 07, 2007 9:46 am
    For some of you this is common knowledge. But I figured it out only after reading a post by ~. He was talking about using grease to hold the small spring behind the oil filter on a 450X. Since then I have used grease more than once to hold various washers and gaskets that don't want to stay in place during assembly.
    If you like this advice all credit needs to go to ~.
    by JAWS » Mon May 07, 2007 4:47 pm
    He learned it from someone else! :)
    by JAWS » Mon May 07, 2007 8:03 pm
    Because we are all the sum of our parts! :)
