SAG
    SoCal450R
    SAG
    by SoCal450R » Thu Apr 26, 2007 12:54 pm
    is there a how to thread about how to set your sag properly? if so can someone post a link to it. Thanks!
    2006 CRF 450R:
    -WB Fuel screw
    -JDJet kit 180 main, 45 pilot, red clip on fifth position, fuel screw 1 1/4 turns out.
    -Promoto Spark Arrestor
    -Flatland Rad. Guards
    SoCal450R
    by SoCal450R » Fri Apr 27, 2007 11:33 pm
    thanks nedirtbikr!!!!!
    2006 CRF 450R:
    -WB Fuel screw
  • staino
    by staino » Thu May 03, 2007 8:20 pm
    Oh this is perfect, exactly what I was looking for :lol: Thanks
    zak13
    by zak13 » Sat May 26, 2007 3:12 pm
    whats the link
  • tim howell
    Alternate Sag setting
    by tim howell » Wed Jun 06, 2007 7:12 am
    Rear Shock
    First extend the shock completely and measure from the axle to a vertical reference point on the chassis. This is L1.
    Take the bike off the stand, put the rider on board in riding position. Get an assistant to balance the bike or have the rider hold onto something, compress the suspension about 25 mm (1") and let it extend very slowly (slowly is the critical term). Where it stops, measure the distance between the axle and the vertical reference point on the chassis again. Do not bounce. This is L2.
    Next lift up on the suspension and let it drop very slowly. Where it stops measure again. Do not bounce. This is L3. The reason L2 and L3 are different is due to stiction or drag in the seals and bushings. (If there were no friction in the seals or the linkage L2 and L3 would be identical.)
    Half way between L1 and L2 is where it would come to rest with no friction. Therefore L2 and L3 must be averaged and subtracted from L1 to calculate true Static Sag.
    Static Sag = L1 - (L3 + L2)/2
    To adjust Static Sag use the preload adjusters.Spring collars are common, and some benefit from the use of special tools. In a pinch you can use a blunt chisel to unlock the collars and turn the main adjusting collar. If you have too much sag you need more preload; if you have too little sag you need less preload.
    Be sure to check out http://www.howellracinginc.com
    djh65
    by djh65 » Wed Jun 06, 2007 7:17 am
    06 HD450X made in america.
