Uni air filter flamable?
  • 449.4R
    by 449.4R » Fri Apr 13, 2007 10:30 pm
    Is this a safe filter with no backfire screen?
    I know the uni oil is flamable.
    Can air filters really catch fire even with no oil?
    by JAWS » Sat Apr 14, 2007 5:43 am
    My answer to you is that it is probably flammable and could catch. Likelyhood is minimal, but it is possible. Wash it out well, let it dry and use NO-TOIL on it. It isn't flammable, plus yu can wash your filters in the wifey's kitchen sink without issue. I use a regular TwinAir with NO-TOIL. When I replace it, I will probably go with the flame retardant version for extra security.
    by [email protected] » Sat Apr 14, 2007 12:52 pm
    The TwinAir with the flame retardent layer you'll like Joe, it's very well made,and fit's really nice . That may seem silly to some, but I've seen aftermarket filters that are all puffed out around the edges, and/or the seams aren't exactly where they're supposed to be.
    I don't use the No Toil products, but I sure would. I've got too many friends that use them and none have any complaints at all, no problems and as far as cleaning air filters go pretty painless.
    The reason I don't is awhile back I got that Twin Air 'System'that I'd put on a "Wish List" for Christmas,not expecting to get it. It's the one that has a cleaning tub and oiling tub,the cleaning tub having a filtering screen in the bottom of it.
    While it seems overly expensive, you get a gallon of cleaning solvent, of really good oil, and I swear you could clean and oil 250 filters with what they give you.
    Once you've set up your tubs it is REALLY easy, you just dunk it and rinse it, then when dry submerge it in the oil and wring it out. It makes really quick work out of the job.
    Before I would do it the hard way , making a general mess of everything. I'm very happy with this TwinAir set-up, but if I didn't have it or had to replace it I'd go with the No-Toil/Honda stuff. Doug
  • 449.4R
    by 449.4R » Sat Apr 14, 2007 6:03 pm
    I got the green twin air pre oiled in the sack.
    Seals real good and easy to take in and out.
    I also gave it a pretty good bic lighter test that would be more severe than a backfire.
    Cheap insurance I guess. I needed a new filter anyways.
