What does the Jet Size Indicate ?
  • topgun
    by topgun » Thu Apr 12, 2007 2:56 am
    Ok here's one for the brain's trust ...
    What does the Jet Size indicate ? I know it is not the physical size of the "hole" in the jet
    I think it relates to the amount of fuel that flows through the jst in a given time period ??
    Just curious ...
    Anyone with a definitive answer ?
    by Aussiecrf230 » Thu Apr 12, 2007 3:29 am
    Generally it is the hole size in millimetres, but I know for a fact some carb manufactures(cars at least) numbers refer to flow rates.
    mustang
    Re: What does the Jet Size Indicate ?
    by mustang » Thu Apr 12, 2007 5:56 am
    topgun wrote:Ok here's one for the brain's trust ...
    Just curious ...
    The numbers on the jets are the size of the hole thru it .
    A main jet that is 100 =1 mm hole
    200 = 2 mm 175 = 1.75 mm etc. , etc.
    pilot jets are the same 42 pilot =.42 mm
    c-ya****mustang Image
  • topgun
    by topgun » Fri Apr 13, 2007 1:49 am
    Mustang
    Not doubting your answer but are you sure on that ? - OK so I am a little skectical ...
    Checked some old Mikuni jets I have and no way would a 1 mm drill bit fit thru a # 100 main jet so that led me to theory of flow rate ...
    Crazy_Steve
    by Crazy_Steve » Fri Apr 13, 2007 2:01 am
    topgun wrote:Mustang
    He's right.
    And the Honda's carb is a Keihin.
    he back.
  • topgun
    by topgun » Fri Apr 13, 2007 2:13 am
    Ok .... yes I am aware of the carbs Honda use :D
    But do all manufacturers use the same method to size jets ?
    Tried Googling it but no real answers to be had ..
    So I am trying the definitive source ... you guys !!!
    And yes I am not being very receptive to your answers which is very rude of me so I apologise ....
    by Asmith » Fri Apr 13, 2007 7:05 am
    topgun wrote:So I am trying the definitive source ... you guys !!!
    I think I found the error in your thinking... :lol:
  • topgun
    by topgun » Fri Apr 13, 2007 5:13 pm
    OIC .... my bad ...
    :D
    by nminus1 » Fri Apr 27, 2007 7:52 pm
    I believe Mikuni uses flow rate, Keihin uses size. Ex Mikuni 100 = 100cc per minute. However this is further complicated as I dont know what psi they are measuring at, I bet at 500 psi it would be more like a litre per minute, must be a nominal value used. I bet some smart M.E. aka AS would know....
    by Aussiecrf230 » Sun Apr 29, 2007 6:12 am
    The standards for flowing heads is a either a vacuum of 10 or 25 inches of water.
    For some reason I think small items were done at 2 inches but I would have to check.
