octane?
    ship_killer6666
    octane?
    by ship_killer6666 » Tue Apr 10, 2007 9:41 am
    how much octane I need for my crf150
    Honda told me to put 98 in it, but I don't think this guy was knowing everything about crf150f
    in you'r owner manual, what it is writted?
    by 124 » Tue Apr 10, 2007 11:53 am
    A 150F will run any octane fuel you can buy at the pump. A 150R will need 92+ for best performance.
    team honda
    by team honda » Tue Apr 10, 2007 11:56 am
    thats right 92+ would be the best :twisted:
    06 CRF 450R,DR.D,tag,DID chain,twin air,white and black
    ship_killer6666
    by ship_killer6666 » Tue Apr 10, 2007 12:53 pm
    so when I buy 94 at the pump and with octane booster I put the octane to 98 thats okay?
    team honda
    by team honda » Tue Apr 10, 2007 5:16 pm
    yeah any premium at a pump should be at least 92 octane i dont know why you would need octane boost i have never seen that much of a difference with my 450
    by Asmith » Tue Apr 10, 2007 5:21 pm
    Octane will help with pre-ignition. A CRF150F has a 9.5:1 compression ratio. Pre-ignition shouldn't be a problem until you are greater than 12:1.
    Adding octane boost is a waste. You will not derive more power from it if that is what you are thinking.
    by JAWS » Tue Apr 10, 2007 5:26 pm
    Ship_killer, unless you have replaced your piston with one that has much higher compression, higher octane will do nothing but cost you money. You will not get better or more power from it.
    In fact, most people that run premium gas in their cars don't need it nor get any benefit from doing so. Lab test have confirmed that over and over. If you don't believe us then look into it on the net. You will see. Just run what Honda suggests.
    ship_killer6666
    by ship_killer6666 » Wed Apr 11, 2007 2:27 pm
    honda did suggest me 98 octane
    if you say that I don't need my octane booster, i won't buy octane booster anymore
    but from 87 octane to 98 I saw a difference
    by JAWS » Wed Apr 11, 2007 3:30 pm
    I don't mean some guy at a Honda shop, I mean the manual that you got with the bike. Your compression ration is only about 9:1. On the 450X the compression ratio is 12:1 and Honda only recommends 91 octane.. that's premium gas to you. There is no way that anything more than 91 octane is going to give you any more power unless you have changed that compression ration and need it. Save your money.
    ship_killer6666
    by ship_killer6666 » Wed Apr 11, 2007 4:52 pm
    k thank you,
    but I don't have my service manual, thats why im asking the question
    by JAWS » Wed Apr 11, 2007 5:28 pm
    You're welcome. Try to find a manual. It will save you a lot of time.
  • RedneckDriver
    by RedneckDriver » Fri Apr 13, 2007 11:43 am
    there is a tag somewhere on the bike that says 90 or better, i run anywhere from 87 to 93 and it does ok
    by JAWS » Fri Apr 13, 2007 3:01 pm
    If it says 90 or better, then run premium which is generally about 91-92 octane. Don't run 87.
    Crazy_Steve
    by Crazy_Steve » Fri Apr 13, 2007 3:23 pm
    On that little bike you could easily run 87 with no problems.
    There's no way that you'd need to run 98.
    A comp. ratio of 9:1 is near nothing.
    My quad only needs 112 and I run 15:1
    High octane in that little bike is useless.
    Don't use octane boost either. It doesn't work the way you think it does.
    he back.
Users browsing this forum: No registered users and 16 guests
