White Brothers carb kit for an 07' 250F
  • wmdspalmer
    by wmdspalmer » Mon Apr 09, 2007 4:17 pm
    Has anyone used this and is it worth the expense? The local Shop has it for around $100. Thought maybe this will help with starting issues and restart when hot. Thanks,
    Will
    by crfsonly » Mon Apr 09, 2007 6:27 pm
    we've had excellent results with this kit. here's a link:
    http://www.crfsonly.com/catalog/product ... ts_id/2240
  • wmdspalmer
    by wmdspalmer » Mon Apr 09, 2007 8:07 pm
    ken,
    Thanks very much for your reply.
    Will
  • crf861
    by crf861 » Fri Apr 13, 2007 9:04 pm
    You can adjust the carb to work better than installing the carb stuffer.
    I have had excellent results with the 06 and 07 bikes with modifying the AP, timing it, and getting the right leak jet installed. Then with the larger carbs, you have to set the floats just a bit lower and it will work great! no bog, no landing issues.
    by crfsonly » Fri Apr 13, 2007 9:12 pm
    the white brothers kit also includes ap mods as well as jets and in the case of the '06 needle.
  • crf861
    by crf861 » Sat Apr 14, 2007 6:00 pm
    But why spend the $99 when you can do it for the price of a few jets? And still have the top end benefits of the larger carb.
