gearing
  • offrdrdr
    gearing
    by offrdrdr » Wed Apr 04, 2007 7:39 pm
    have any of you guys or gals changed the gearing on your 250x? i race enduro's in the southeast and 2nd gear seems to be a little too tall and 3rd not quite tall enough for the tight woods. any suggestions would be greatly appreciated.1st time posting. 06 250x
  • redrooster65
    by redrooster65 » Wed Apr 04, 2007 8:20 pm
    I dropped a tooth in the front and am very happy with the gearing, esp in the tight stuff. I am not a racer though
    Monkeywrench
    by Monkeywrench » Wed Apr 04, 2007 8:55 pm
    I'm curious: do you mean 2nd gear feels like you have to whine it out too high to make decent use out of it? As well as when you shift to 3rd it feels luggy? If this is what you're describing, yes I agree with you 110%. 3rd gear in the woods with the stock setup is almost a let-down, once you have begun to get good at turning fast, and want to increase your overall speed. You start using 3rd only to find it lugs too much, unless you have screamed fresh out of 2nd gear before moving to 3rd. :x
    I haven't had a chance to try mine yet, but I just switched to 13/51, which would be the same as running 14/55 (except no one makes a 55-tooth rear sprocket). I'll let you know how that feels vs. stock, but from what I understand it will be snappier in throttle response, but lose some overall top-end speed. I understand this is also the stock setup on 250R's - I'll let you know what it's like, hopefully in a couple days time. I'm hoping it will help 3rd gear out, which it should! (Might render 1st gear pretty useless, unless I'm stuck in a cake-batter/rainy day mud field). :-k
    2006 450R
  • offrdrdr
    by offrdrdr » Wed Apr 04, 2007 9:10 pm
    you are right monkeywrench, i have to rev the snot out of it in 2nd and in 3rd i have to use a lot of clutch. please let me know what you think of your gearing after your ride. i got another enduro coming up in the mountains of alabama. sure to be some tight goat trails there. thanks for the input.
  • dirtbike_pete
    by dirtbike_pete » Thu Apr 05, 2007 6:59 am
    Hello offrdrdr:
    The stock countershaft sprocket from the 250R is one tooth smaller than the 250X. It made my X much more managable in the "tight stuff". I was never satisfied with the stock gearing before hand, found too much clutching in first and a gap in ratios between 1st and 2nd gears. Try it, you will love your 250X all over again! Peter :D
    CRF250X,50th Birthday Gift to Myself, awesome bike!!!
  • offrdrdr
    by offrdrdr » Thu Apr 05, 2007 5:24 pm
    dirtbike pete, i have a 13 tooth counter shaft sproket. i think i will ride with it this weekend and see how it goes. thanks
  • dirtbike_pete
    by dirtbike_pete » Mon Apr 09, 2007 8:39 am
    Hello offrdrdr:
    Let me know how you liked the gearing change! I am jealous, as its still too cold (around 32f) and the weather can't quite decide if we are going to have rain or snow! :roll: Just nice to hear of others out there riding.
    Peter :)
  • 500MELON
    by 500MELON » Mon Apr 09, 2007 3:36 pm
    Hey guys I thought i would chime in here.
    I had the same problem with 2nd and 3rd as described.
    I ran a 13/53 this past weekend and it was great for me.
    It seemed as if i was always between those two gears before.
    Now I can run 3rd gear most of the day. Much more "tractable" power coming out of hard corners.
    06' 250x
    jd jet kit,twin air,drilled baffle,cut airbox,hot cams
  • offrdrdr
    by offrdrdr » Mon Apr 09, 2007 6:06 pm
    hey guys, 500melon is right, i tried the same combo and that seems to be the ticket for me. you guys are the greatest. thanks
