TICKING NOISE FROM VALVE COVER
  • NorCalDuner
    by NorCalDuner » Sun Apr 01, 2007 10:15 pm
    I just got done with a top end rebuild, 12.5:1 je piston,SS kibble white valves, ported the head. I started it for the first time yesterday and everything is good except for a ticking noise coming from the valve cover or somewhere up top. Its not the same ticking noise that it used to make when stock, that was more of a knocking. The knocking is gone but this ticking is concerning me. Tonight I pulled the valve cover and checked the clearances and they are all in spec. I first thought it was the decomp clearance but it is set @ 24. Has anybody else had this problem?
    2005 crf450r Yoshi Slip On
    2006 trx450r ESR full exhaust,
    HCSII cam
    by 124 » Mon Apr 02, 2007 5:57 am
    Take some oil and LIBERALLY coat the crap out of the decompressor. Make sure to get it on and in around where the inertia arm contacts the little pin that protrudes from the cam.
    Had the same issue after my rebuild...
  • NorCalDuner
    by NorCalDuner » Tue Apr 03, 2007 7:34 pm
    I lubed everything up with molybenum and oil mixture. Ticking is still there, do you think it could be the stainless valves are louder than titanium?
    HCSII cam
    woodsman
    by woodsman » Tue Apr 03, 2007 8:11 pm
    :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock:
    You have a ticking time bomb look out!
    Currently, 05 450X
    by 124 » Wed Apr 04, 2007 5:20 am
    NorCalDuner wrote:I lubed everything up with molybenum and oil mixture. Ticking is still there, do you think it could be the stainless valves are louder than titanium?
    No. Timing chain tensioner functioning properly and set to the proper tension?
    Have you done the stethoscope trick? You can get a pretty good idea of where in the engine the sound is coming from with a long screwdriver (or stethoscope if you can get your hands on one)...
    Now that I think further, is this a normal sound that you are over thinking? Mine makes all kinds of racket. Sounds like someone threw a couple loose bolts in the top end...
  • dunecharger450
    by dunecharger450 » Tue Apr 10, 2007 10:28 am
    Have you checked the decompression clearance between the arm and the right exhaust valve? That noise is most certainly the decompressor arm slapping against the cam because there is too much freeplay. This is a common noise upon rebuild.
