Clinking noise on 05 450r during take off and accelerating
  • kiwiflyer
    by kiwiflyer » Sun Apr 01, 2007 1:31 pm
    Can anyone suggest a cause for the following problem? When I take off on my 05 450r I get a clinking noise from somewhere down below. This only happens periodically and normally when the power is wound on in 1st and 2nd. I think it may be the chain slipper slapping against the swing arm but cant seem to isolate the problem. I have checked chain tension etc. Has anyone else encountered this?
  • T.RexRacing
    by T.RexRacing » Sun Apr 01, 2007 4:17 pm
    Yeah it's the chain whacking the swingarm.Annoying but no problem.I try to run higher rpms but you can't always do that.You get used to it.
    If you have no fear,you haven't been fast enough.............
  • kiwiflyer
    by kiwiflyer » Wed Apr 04, 2007 12:33 am
    Cheers,
    The chain isn't actually hitting the swingarm, but thought it could be the slap of the small gap between the slider and the swingarm. I have heard of putting silicone glue between the slider and the swingarm. This should also reduce any swingarm wear. Anyone have any other ideas?
    by 124 » Wed Apr 04, 2007 5:27 am
    There are aftermarket companies that provide new chain sliders that are supposed to eliminate this phenemonon. Can't think of any names right now...sorry.
  • MadMatt
    by MadMatt » Wed Apr 04, 2007 8:36 am
    Mine does the same thing, I just adjust the chain and it seems to fix it so far.
    this might help
    http://rubicon.off-road.com/dirtbike/pr ... /tmdesign/
    2005 crf450r
    1971 z50
    1984 odyssey fl250
  • T.RexRacing
    by T.RexRacing » Wed Apr 04, 2007 4:45 pm
    kiwiflyer wrote:Cheers,
    I did the silicone thing.Worked for awhile and had to reapply.Oh and I meant the slider not the swingarm.
