Helithumper wrote:It might be a little late but if you have a steering stabilizer the wiring can get routed poorly and when you eat it with the wheel cranked to one side or the other the starter wire will get pinched and break.
Had to run mine back into the shop to have them find what had happened. The wire was broken inside the shielding and unless a multimeter was used it was impossible to see.
Good luck.
