JAWS wrote:Load??Have you checked where the exhaust is connected at the head and at the junction of the headpipe and muffler? Do you have any holes in your pipe?
Hard starting... If this is fairly new, have you checked your valves? The scenario that you indicate, i.e. pull/push starts OK but will not kick, is a classic valve symptom. It can be other things, but if nothing else has changed, then there is where I would start.
124 wrote:JAWS wrote:Load??Have you checked where the exhaust is connected at the head and at the junction of the headpipe and muffler? Do you have any holes in your pipe?
You gettin bored in the "X" forum Joe??
You're on top of things lately!! You're killin my post count man!! J/K
jeremy.simmons2 wrote:I HAVE HAD THE VALVES CHECKED WITHIN THE LAST MONTH. EVERYTHING WAS FINE. LOUDNESS STARTED ALL AT ONCE, SEEMS TO HAVE LOST A LITTLE POWER SINCE THEN, NOT MUCH.
