Jetting question
  • bartlow21
    Jetting question
    by bartlow21 » Sat Mar 03, 2007 5:04 pm
    Does any one have any good jetting set ups for a 2006 crf 450 at 500 ft above sea level?
  • Halen
    by Halen » Sun Mar 04, 2007 7:28 am
    JD jetting has all sorts of good setups... :lol:
    Van.
    09 CRF 250R
    RMR lowered suspension
    Heavily armoured for the bush
    50 tooth rear
    soft gel seat
  • bartlow21
    by bartlow21 » Sun Mar 04, 2007 4:17 pm
    I trying to kill the bog when whack the throttle .
    by [email protected] » Sun Mar 04, 2007 5:24 pm
    When you're moving, or while sitting there at idle ?
    If it's while sitting,that's normal. Doug
  • bartlow21
    by bartlow21 » Mon Mar 05, 2007 1:42 pm
    When I'm riding it. IF I roll the Throttle on it's OK .IT only does it at low RPMs .
  • nedirtbikr
    by nedirtbikr » Mon Mar 05, 2007 4:07 pm
    I went with the JD kit (I typically ride at about 1000' ASL - you should have about the same jetting as me)...
    - Red needle, 4th clip (I think...will have to make sure on this,)
    - 48 pilot
    - 1-1/8 turns out on fuel screw
    - TwinAir powerflow filter
    I have no, none, zero, nada bog at idle or while running it. If I whack the throttle and don't keep my wits about me, it'll throw me right on my arse...at pretty much gear.
    2006 CRF450R (For Sale)
  • chv
    Boog...
    by chv » Sun Mar 18, 2007 9:04 pm
    All i have done to mine is a Pro-Circuit Pipe T-4 and a 172 main. I ride all elevations from sea-level to 8000' and have never had any problems always starts on 2-3 kicks.
    Chad
    450R, 250X
