trailering your bikes?
  • hype143
    by hype143 » Thu Mar 01, 2007 6:25 am
    Do any of you guys use a suspension saver or do you just ratchett down your front suspension a little?
    by XGiant » Thu Mar 01, 2007 6:46 am
    I use a suspension saver so there is no play in the tie downs, and my suspension does not compress more than maybe an inch.
    KevinM
    by KevinM » Thu Mar 01, 2007 6:51 am
    I just bought two of them for our mini's.
    I've been told cinching down the mini's too much is not a good thing for their springs or seals.
    I haven't seen too many people using them on the bigger bikes though. But I'd have to say it seems like a good idea. Especially if it's on the trailer a long time.
    09 CRF 450R
    07 CRF 250R
    FS 2 trns
    05 CRF 250X
  • DaveX
    by DaveX » Thu Mar 01, 2007 10:26 am
    I use them all the time and think it is worth while - I have lost one before and the tie downs then become loose so I put a bungie cord around it and the forks.
    Dave
    05 450x
    Acerbis Rally II Hand Gaurds
    Flatland Rad Gaurds
    Applied Bar Clamps - black
    Pro Taper KX High Bars - black
    Pink wire mod / Applied Vent kit
    Fastway case saver
    JD kit 170/ red needle clip in middle
    Twin Air / air box mods
    Quickshot APC
  • ANYTHNGFAST
    by ANYTHNGFAST » Thu Mar 01, 2007 11:42 am
    I have tried using a seal saver many times but even with a rubber band or a bungie it always works itself loose, in turn the tie downs come undone and you are at risk of losing the bike. Id rather buy new seals than a new bike. Maybe a different brand or style would be better? For me its not worth the time or effort.
    ps I am not very slow in my truck on the dirt either- even loaded with bikes. :twisted:
  • ThumperX
    by ThumperX » Fri Mar 02, 2007 10:16 pm
    I blew 3 fork seals (same one everytime) when having the bike tied down. Now with my seal saver i've yet to see one leak (knocks on wood).
    05' CRF250X
    07' CR250R
    02' CRF450R
    instigator
    by instigator » Sat Mar 03, 2007 12:30 pm
    [quote="ThumperX"]I blew 3 fork seals!
    Did it taste like a regular seal? :lol:
    pro circuit T-4
    Jd Kit
    smog block-off
    the "works" for guards
    ___________________
    LET'S ROLL!
  • Motomike41
    Bike Shoe
    by Motomike41 » Wed Mar 07, 2007 5:42 pm
    I use a bike shoe that locks on the front tire and I don't have to use any straps!! Been using them for years and they work great.
    JimmyPwadd
    by JimmyPwadd » Thu Mar 08, 2007 5:01 am
    I use a homemade fork support and seal savers.
    HOPEFULLY my seals will last longer than I do.
    (please don't ask my wife) :shock:
    2006 CRF250X
    Boyesen Quick Shot /AP mod
    by Asmith » Thu Mar 08, 2007 6:30 am
    instigator wrote:
    ThumperX wrote:I blew 3 fork seals!
    :lol: :lol: :lol: :shock:
    by JAWS » Thu Mar 08, 2007 7:04 am
    Since I had my fork springs replaced to stiffer for my weight, I cannot ratchet my forks down much at all. Maybe an inch. I doubt that is going to cause much of a problem, so I haven't worried about it.
    by Aussiecrf230 » Mon Mar 12, 2007 4:59 am
    I have found if you rachet down front and back the bike stays steady as a rock. You don't have to go full travel either.
    I use a block of wood(poor mans seal saver) on my sons CR80R as upside down forks seem to leak more often. I tie down the back on it as well.
    That's my two cents worth anyway, what ever works for you and keeps it in the trailer is good.
    Bamm Bamm
    by Bamm Bamm » Sat May 19, 2007 12:41 pm
    I use themmm the one time I didn't i blew one of my seals on my 450x now there both blown.. ARGHHH..
    06' CRF450X-Pro-Circuit T-4, Hot Cams Stage2, Kibblewhite valves, JDJ kit 170 main, 48 pilot, K&N A/F, PC- T-4, FMF powerbomb,R&D fuel screw, Ziptye float bowl, lots of Carbon fiber, 14T-51T, Black Plastics, mirror polished frame(now dull)
    Roady
    by Roady » Fri Jun 01, 2007 8:39 pm
    Been using them for several years now ... they do occasionally come loose, but I use carabiners (sp?) on the end of my tie downs also, so there is no risk of he bike disconnecting from the truck.
    I have a couple of the ATK bike shoes that I used to use on my kids bikes, but I don't really like the way it locks the front wheel but allows everything else to sway ... probably ought to Ebay them or something.
    It is a good day to ride
    uniped
    by uniped » Fri Jun 01, 2007 10:11 pm
    I use one as well never lost one yet. the only time i don't use it is if I load my bike single in back of my pickup. love that stupid little thing keeps my bike very solid on the trailer.
    ________
    Vaporizer volcano
