How do I stop the chain from eating up the rear tire?
  • nate815
    by nate815 » Sat Feb 24, 2007 9:44 pm
    I always have trouble with chains having so much side to side slop it chews up the rear tire. I need help preventing that.
    coljam
    by coljam » Sat Feb 24, 2007 10:00 pm
    I have never heard of this being a problem. My guess would be either a) a overly loose chain, which could cause other even worse problems, or b) a problem with the chain guide.
    by JAWS » Sun Feb 25, 2007 7:40 am
    Or a completely worn out chain!
  • 150_red_rider
    by 150_red_rider » Fri Apr 13, 2007 8:40 pm
    Wow, never heard of that!!
  • randman1
    by randman1 » Fri Apr 13, 2007 11:02 pm
    maybe rear wheel not centered + cheap chain + way to loose????? :shock:
    http://crfsonly.com/forum/garage.php?mo ... le&CID=512
    Remember it's not how well you ride, it's that you ride!!!
  • CJFonner
    by CJFonner » Sat Apr 14, 2007 5:05 am
    An effective chain wont have much side to side play at all. I had this problem on my new 450R after about 3 rides. I replaced it with a new x-ring chain and havent had a problem since. Hate to break the news to you, but it's time for a new chain.
    I guess it could also be that your rear wheel is out of line, but it would really have to be sideways for a good chain to hit it.
  • MadMatt
    by MadMatt » Tue Apr 17, 2007 12:28 pm
    I had the same problem with my 450r. Taking out some of the slack helped for a bit, but the chain has to be replaced.
    2005 crf450r
    1971 z50
    1984 odyssey fl250
  • motomanx
    by motomanx » Sat May 22, 2010 5:07 pm
    if you are running a 120 rear, even a brand new chain will chew it up a bit.
    run a smaller tire.
    don't run the chain too tight!
