ice cube cylinder kit
    woodsman
    by woodsman » Thu Feb 22, 2007 7:05 pm
    Have you folks considered selling this?
    302cc Big Bore & Stroker Engine Kit
    "We tested RPM's awesome Honda CRF302 kit and came away impressed by the horsepower."
    Motocross Action Magazine, May 2005
    See what Dirtrider says about the CRF302 (PDF 2MB)
    $2,360.00 Bolt in
    $475.00 Optional installation charge
    -$200.00 Stock cylinder and crankshaft core credit (subject to inspection)
    CRF 302 ICE CUBE Specifications:
    Fits 2004-2006 Honda CRF250R and CRF250X
    Bore = 82mm Stroke = 57.2mm Displacement = 302cc
    Engine Modifications Included:
    Cylinder: Billet aluminum cylinder with a forged aluminum sleeve plated with Apticote 2000 ceramic bore coating.
    Head: No head work needed.
    Crankshaft: Stroke, balance and true.
    Crankcase: Modifications necessary!! Case machining is included with installation charge. We will split, inspect, machine and reassemble your engine with a longer rod kit. If you purchase a "Bolt in kit": The crankcases must be machined to clear cylinder skirts and the connecting rod. You can send your cases to Maxpower to have this done ($300 for disassembly of the engine and $100 for machining), or Maxpower can send you photos and instructions.
    Blueprint: Calculate deck height, squish clearance, trapped volume, and compression ratio and list on your perminant Spec-Sheet.
    All of our engine kits are
    built using Wiseco Pistons
    Benefits:
    More horsepower
    More torque
    No spacer plate required
    Holds more coolant
    Stronger than the stock cylinder
    Kit includes:
    ICE CUBE cylinder by
    1 Piston kit with piston, rings, wrist pin, circlips.
    1 O-ring head gasket
    1 Base Gasket
    Ign and clutch cover gaskets
    Center case gasket
    RPMs Long Rod Stroker Kit (long rod stroker crank, longer cam chain and guides, longer head bolts)
    For installation this kit requires you to send us:
    Your complete CLEANED engine with NO OIL or COOLANT
    Kick starter and shifter
    Upper motor mounts
    Generator
    Delivery: Call to check availability of completed cylinders and cranks.
    Special features: This kit is also available as an unassembled "bolt in" kit, for $2,360.00. We will send you an ICE CUBE cylinder and crank assembly with all the modifications listed above, Maxpower long rod kit, and a piston/gasket set ready for you to assemble in your motor, allowing you to keep your stock parts and keep racing until your kit arrives. Note: The crankcases must be machined to clear the cylinder skirts.
    :twisted:
  • ThumperX
    by ThumperX » Thu Feb 22, 2007 10:56 pm
    I'd buy a 450 before I even thought of buying that kit...
    05' CRF250X
    07' CR250R
    02' CRF450R
    by Asmith » Fri Feb 23, 2007 4:47 am
    ThumperX wrote:I'd buy a 450 before I even thought of buying that kit...
    And you would have 15 more horsepower and $2000 more dollars.
  • ThumperX
    by ThumperX » Fri Feb 23, 2007 11:03 am
    Sounds alot more reasonable than putting $2300 into a big bore... BTW, it was only $1000 difference between my dads 450x and my 250x, the only reason I didn't get the 450 is that I had no previous riding experience.
    05' CRF250X
    07' CR250R
    02' CRF450R
