Oil Leak
  • War450
    Oil Leak
    by War450 » Sun Feb 11, 2007 2:05 pm
    First of all this is a great site. I had a front fork leaking. Tried the film negative trick. So far so good. So thanks to all.
    Now I noticed a leak at the countershaft (drive sprocket). Parts fiche shows an oring and a seal. Is it usually the oring leaking or the seal? Or both?
    Also, I have average maintenance type mechanical ability. Routine maintenance such as brakes, r&r chains & sprockets, Oil change, etc...
    Is this a difficult repair? Maybe someting the average joe can do?
    Thanks,
    Doug
    by 124 » Mon Feb 12, 2007 6:33 am
    It's the seal and you can do it yourself. Easy one...
  • War450
    by War450 » Mon Feb 12, 2007 1:26 pm
    Got the sprocket & Collar off. Does the seal just pry out? Do I need a special tool?
    Thanks
    by 124 » Tue Feb 13, 2007 8:08 am
    Pry it out with a small screwdriver or hook. It should pop right out. Make sure not to damage the sealing surface...
  • War450
    by War450 » Thu Feb 15, 2007 10:22 am
    Thanks for the help. Before pulling the seal out, I cleaned everything real good with the collar out. Reinstalled everything and rode it. It set for a while. Pulled the sprockett back off. It doesn't appear to be leaking anywhere.
    We'll see.
Users browsing this forum: Google [Bot] and 6 guests
