New White Bros e2 jetting suggestions?
  • SDBRIAN
    by SDBRIAN » Sun Feb 11, 2007 10:52 am
    Just recieved new white bros e2 pipe for my crf450x, and was wondering if rejetting was absolutely necessary. If so what jets and how much am I looking at for rejetting. Thanks.
    Thomas Coker
    by Thomas Coker » Sun Feb 11, 2007 4:59 pm
    You may want to check with White brothers. I run a Pro Carbon on a 04 450R and rejetting is not required.
    2004 CRf450R
    White Brothers Pro Carbon Exhaust, Pro-Grips, Michelin S12, Works Connections Skid and radiator braces, Fastway Billet Shark Fin, ASV C/5 Levers, Uni Filter, Engine Ice
    whoya
    by whoya » Sun Feb 11, 2007 7:04 pm
    Put it on and run it. See what happens. Have you done any other mods to the airbox or anything? If not and you dont want to totally rejet you can probably get away with maybe just lowering the clip on the needle a position or two and opening the fuel screw a tad. but again ride it first and report back.
    01' WR250F mods and dollars added
    by crfsonly » Sun Feb 11, 2007 11:29 pm
    typically if your bike is jetted correctly and your only addition is a slip-on you likely will not need to rejet. however, if you are already lean or on the edge then you will need to rejet.
  • SDBRIAN
    by SDBRIAN » Mon Feb 12, 2007 11:51 am
    I bought the bike in DECember and have not done anything to it yet, so it is all stock.
