moosemauler wrote:hey guy. shim your valves. the smallest shim you can get is a 1.20. If you are on a 1.20 you need to invest in a new valve. I have had 450s and 250s and they do the same thing. Once the valves start to go, start saving for new valves. I will get one ride per adjustment until I replace the valve. I would say your valves are probaly fine. Adjust them to where they need to be and ride. Check them more frequently and you will see a trend and will be able to prepare for a valve job.
Users browsing this forum: Google [Bot] and 8 guests
