honda jets
    alexander
    honda jets
    by alexander » Sun Feb 04, 2007 8:10 pm
    i recently installed a42and a158,cut my airbox,removed backfire screen,changed to a twin air filter,msr fuel screw,and removed the exhaust insert.i ride at sea level to1300ft.is the 158 to large?and what is mod that some of you done to the a.p.?thanks alex 04 250x
    by Asmith » Sun Feb 04, 2007 8:36 pm
    No, I think you are on the right track.
    Are you running the JD Kit?? That needle makes a big difference.
    If not run the R needle P/N 16204 MEN 671 on the 4th clip. Its about $ 14 from the dealer.
    The AP mod consists of putting an O-ring on the throw arms of the Accelerator Pump thus reducing lag time between throttle movement and squirt.
    PM with your e-mail address and I'll send you the whole mod on PDF. Most of us only do the first part with the o-ring. That is enough to eliminate any bog.
    mariom676
    by mariom676 » Sun Feb 04, 2007 8:40 pm
    2005 CRF450R
    Shortened exhaust w/promoto
    twin air powerflow
    09 faceplate & fender
    2005 CRF450X
    Full Supermoto Trim
    warp 9 wheel setup
    Michelin Pilot Powers
    kush drive sprocket on the way
    alexander
    by alexander » Sun Feb 04, 2007 8:58 pm
    will the jetting changes open up third.or is that a hotcam install.thanks again
