JETTING????
    Clint-137
    JETTING????
    by Clint-137 » Fri Feb 02, 2007 11:02 am
    Ok well i just put an Athena big bore kit 280cc, hot cam, white bros carbon pro2, power now system, boysen quickshot, and a different airfilter. i still have stock jetting, its an 05', i also life in north texas, any suggestions please??
    Re: JETTING????
    by Asmith » Fri Feb 02, 2007 11:08 am
    Clint-137 wrote:Ok well i just put an Athena big bore kit 280cc, hot cam, white bros carbon pro2, power now system, boysen quickshot, and a different airfilter. i still have stock jetting, its an 05', i also life in north texas, any suggestions please??
    Yeah,
    change your jetting!!
    You will probably want to go with a JD jetting kit but you will want to go a little larger on the main. I would think with a big bore AND a Hotcam you will need Probably a 165.
    Red Needle 5th clip
    #42 Pilot jet.
    Try PM'ing Christi20. She did this a little while back and has redone her jetting. See what worked for her.
    Clint-137
    by Clint-137 » Fri Feb 02, 2007 11:15 am
    alright, thanx man., ill look into it, but i ordered a fmf jet kit for it. not realizing in the fine print, (use with fmf exhaust), well the biggest jet is a 150. And isnt my stock a 172 or somethin like that?
    by Asmith » Fri Feb 02, 2007 11:33 am
    Clint-137 wrote:alright, thanx man., ill look into it, but i ordered a fmf jet kit for it. not realizing in the fine print, (use with fmf exhaust), well the biggest jet is a 150. And isnt my stock a 172 or somethin like that?
    I assumed it was a CRF 250X...Is it an R??
    If so then yeah, you will need 178 or 180.
    Clint-137
    by Clint-137 » Fri Feb 02, 2007 11:34 am
    ya, sorry its an 2005 crf 250 R, so i will need about a 180?
    280cc big bore kit.
    Hot cam
    white bros. carbon pro2
    Power now system
    boyesen quickshot
    EBC clutch
    customized race tech suspension
    renthal twin wall
    universal top triple clamp...
    Clint-137
    by Clint-137 » Sat Feb 03, 2007 8:49 pm
    Thanx, i just did that i went up to the local store and bought me a 180 and a 182, but we put the 180 in there and moved the clip, now it runs like a raped ape =D>
    280cc big bore kit.
    Hot cam
    Power now system
    boyesen quickshot
    EBC clutch
    renthal twin wall
