Pink Wire mod?
    wezza-mx
    Pink Wire mod?
    by wezza-mx » Wed Jan 31, 2007 6:38 am
    Who can help, i have heard alot of this Mod, but what does it do and how do i do it? any links out there? the link to russels was not to clear enough plus he had a switch on it. :?
  • Halen
    by Halen » Wed Jan 31, 2007 7:53 am
    ~ will help you... he will say that the pink wire controls the Rev limiter. By bypassing or 'removing' the pink wire from the circuit, you are technically removing the rev limiter from the power cycle. You will be able to increase the top end revs by 500 rpms. Good for the top end punch... but a little hard on the valves if you are consistently running you bike pinned out. Agent?
    later... Van
    p.s. thats the way it works on a 250X... I think.
    09 CRF 250R
    RMR lowered suspension
    Heavily armoured for the bush
    50 tooth rear
    soft gel seat
    by Asmith » Wed Jan 31, 2007 8:48 am
    True.
    You will not see any power gains as the ignition curve is designed to work with the R cam. If your aren't running the R cam then you won't benefit.
    As for the extra 500 rpms?? Why? the bike revs high enough, you stop making power before 10,000 rpms anyhow.
    wezza-mx
    by wezza-mx » Wed Jan 31, 2007 8:50 am
    Thanks for the feedback halen, I will see if the agent can help? iv'e carried out the airbox mod and removed the spark arrester. I look to re-jet the bike soon. I'm going to bag me a red rocketship....
  • Halen
    by Halen » Wed Jan 31, 2007 11:57 am
    weeza... I'd be looking to re-jet NOW.
    The bike is very lean to start with, by allowing more air into the system (i.e. airbox mod etc.) it makes the problem worse. Balancing the fuel/air ratio is very important. Some may dis-agree but IMO doing one mod without the other is not a good idea. Jets and airbox modification should be considered ONE mod.
    Look to some of the 'senior' guys here and read up on the posts... you'll find awesome information, from some awesome people that know their stuff.
    later...
    Van
    09 CRF 250R
    50 tooth rear
    soft gel seat
