Steering Stem Lower Tapered Roller Bearing Part Number
  • Serp
    by Serp » Sun Jan 28, 2007 5:13 pm
    Anyone happen to have the common (non-honda) part number for the lower tapered roller bearing and race for the steering stem?
    Thanks.
    2004 CRF250X
  • matt watt
    by matt watt » Mon Jan 29, 2007 7:17 pm
    If its any help the micro fish says its the same as the top one. Sometimes the fish will give the common number but not this time. The micro fish is on line at yamahaoftroy.com.
    04 CRF250X
  • Serp
    by Serp » Tue Jan 30, 2007 6:30 am
    Thanks Matt, that does help. The website link will be helpful for many things too.
    2004 CRF250X
  • Serp
    FYI - Needed to buy OEM
    by Serp » Wed Jan 31, 2007 6:47 am
    The bearing has a "common" NTN number right on it but I couldn't get an aftermarket bearing. There is a really good bearing place I have been dealing with for a long time that couldn't get one for me (B.C. Bearing). They said the NTN number is unique to the manufacturer so I would have to go OEM. I've ordered the bearing and both seals from Honda.
    The lower bearing is hard to take off and needs to be pressed or cut off.
    2004 CRF250X
    by Aussiecrf230 » Thu Feb 01, 2007 3:51 am
    You will find with a lot of genuine bearings are actually slightly different dimensions to the generic bearing.
    Same number, same manufacturer.
    The CR80 stem bearing is a classic example where the generic bearing is 25mm I.D. and the Honda one is 26mm I.D.
    You can get a non-factory bearing now, but it is a lower load rating.
  • dirtdevil1983
    by dirtdevil1983 » Thu Feb 01, 2007 8:09 am
    Yeah be careful getting that bearing off. Its a pain in the @SS. Why not just order the pivot works kit? It will come with both bearings, races and seals.
