jets for 05 crf 80f
    seth_riggle
    jets for 05 crf 80f
    by seth_riggle » Wed Jan 24, 2007 5:18 pm
    im looking for jets for crf80f and does anybody know what to gap the plug at?
  • turnerc
    by turnerc » Mon Feb 12, 2007 7:04 pm
    I ordered jets for our 2006 CRF80 here's what I ordered:
    1- Adjustable Needle Set Part #16012-GN1-A41
    1- Screw Set Part #16016-143-620
    1- Main Jet #100 Part #99101-116-1000
    The adjustable needle was to replace the stock one which is not adjustable. I set the new one on the second clip from the bottom. I ordered the screw set to replace the stock air screw with a normal slotted head screw. The air screw was set to 1-1/2 turns out. I replaced the main jet with the #100. The stock pilot jet was #35 and I left it the same.
    The baffle was also removed from the exhaust and I put an aluminum tip in its place.
    I run my spark plug gap at .028 to .030
    Hope this helps!
    I know our CRF80 runs 100% better now.
    Turnerc
  • tibs
    by tibs » Mon Sep 24, 2007 2:15 pm
    turnerc wrote:I ordered jets for our 2006 CRF80 from http://www.servicehonda.com
    Here's what I ordered:
    Turnerc
    will the adjustable needle and screw set fit a 07 crf70f?
    and with the screw set how did you get the old one out?
  • baddlord777
    by baddlord777 » Tue Sep 25, 2007 11:46 am
    Hope this helps!
    Turnerc
    Where on Honda are you locating adjustable set(s) etc ? I thought honda was strictly stock Factory parts ? :? Or did you call them ?
  • 2stroke
    can you tell me if this jetting would work on a 2005crf80? I
    by 2stroke » Mon Dec 03, 2007 9:12 am
    Hope this helps!
    Turnerc
  • MauiCRF450Rider
    Re:
    by MauiCRF450Rider » Fri Dec 31, 2021 3:18 pm
    Turnerc
    I just ordered the needle set and screw set off the '05 CRF80f schematic for my son's 2012 CRF80F and everything fit as expected.
    I did however purchase the Main jet from the aftermarket listing instead of the OEM list as it has more options, and cost was better.
Users browsing this forum: Google [Bot] and 0 guests
