devistation wrote:And I'm wondering how it fit's with the Acrebis Rally pros?? I know someone here has it..
paul turner wrote:devistation wrote:And I'm wondering how it fit's with the Acrebis Rally pros?? I know someone here has it..
Dev
this one makes me and my Cycras Happy,
http://www.mooseracing.com/catalog.jsp? ... up_id=4449
paul turner wrote:Dev
dlpmx wrote:I have discovered the Moose clamp on grips. They are molded on to the throttle tube and a tube for the clutch side. For $20 you get both grips. Best part they don't slip. No more glue,hairspray,spray paint or what ever you hold them on with. $20 for the grips molded onto throttle tube seems pretty cheap to me.
Dale
Ken should be able to get them for you also.
Dev
crfsonly wrote:we carry the moose throttle tube as well. here's a link:
http://www.crfsonly.com/catalog/product ... ts_id/1878
pro taper has stopped making the handguard insert for the twister throttle tube. not really sure why as it worked well. as a result this makes the twister throttle tube not compatible with bar end mounted handguards.
