Dim Headlight
  • PhilM
    Dim Headlight
    by PhilM » Fri Jan 19, 2007 4:47 pm
    Is yours real dim at idle, like almost brown and then get bright with throttle? Were you able to correct it? If so, how?
    Thanks
    Monkeywrench
    by Monkeywrench » Sat Jan 20, 2007 3:58 pm
    No correction available unless you rewire the light to run straight off the battery, with a switch or something.
    Easy fix is just to ride fast if you're riding in the dark! :D
    2006 450R
    AT
    by AT » Sat Jan 20, 2007 10:35 pm
    Mine does that too. It's kinda annoying
    05 CRF250X
    04 CRF150F
    05 Sikk Mx Pit Bike
  • PhilM
    by PhilM » Sun Jan 21, 2007 2:21 pm
    Is the headlight AC or DC??
    AT
    by AT » Sun Jan 21, 2007 5:58 pm
    PhilM wrote:Is the headlight AC or DC??
    Uhhh no idea. It's the stock hedlight for an 05 250x
    05 CRF250X
    04 CRF150F
    05 Sikk Mx Pit Bike
  • PhilM
    by PhilM » Sun Jan 21, 2007 6:11 pm
    I was curious as sometimes the lights are powered off the ac side of the rectifer.
    by paul turner » Sun Jan 21, 2007 6:20 pm
    Idle should be 1500-1700rpm, this may correct the dimness.
    nowazzu
    by nowazzu » Sun Jan 21, 2007 6:53 pm
    I hated that when I had the stock lighting setup. It runs from the AC side and will dim as the RPM's drop. Now I run it DC off the battery with a Baja Designs HID light.
    -nowazzu-
    05' CRF450X
